Here is the plan. Please add your recommendations.
1. Get as many parts out of the way as I can.
2. Remove reservoir hoses at the MC and drain into a container or plastic bag. I plan on using a dremel to cut the clamps.
3. Remove reservoir with hoses attached from car.
4. Remove brake lines using a flare wrench. I have been soaking the nuts in rust release penetrant.
5. Remove MC
6. Bench bleed new MC
7. Instal new MC.
8. Put new hoses on old reservoir and instal in car and attach the hoses to MC. Hose need to be rated for brake fluid.
Concerns: I have the dual reservoir. Will the new hoses fit on both plastic nipples on the reservoir and the MC? Will the acorn nut be set properly to the new MC?
Questions: What else can I be doing when the MC is out?
