Trunk Light
Trunk Light
I have a black and yellow wire in my trunk without a bulb. Is this the trunk light? What bulb does it take? Thanks
Re: Trunk Light
Yes, it is for the trunk light. But be careful, that wire connects to a part of a very iffy base for the light. It is very common for it to wiggle itself into contacting the base of the holder, which is the ground. Not good. When I posted that I kept blowing fuses and traced it back to the trunk light I heard back from a lot of people who had the same issue. Everyone who responded said that they didn't use the trunk light. To use the trunk light, your parking lights have to be on and a door has to be open. I ended up giving that wire a constant 12v source and wiring in a switched utility light on about a 2' lead. If I need light in the trunk I can move the light where I need it. The original position of the trunk light is next to the battery in the newer cars and that blocked off the light from 3/4 of the trunk anyway. As to what bulb it takes, ??
- perthling
Re: Trunk Light
I still have the base and bulb, but wondered if it ever had a clear diffuser over the top. Anyone able to post a pic of what it looked like originally? Mine's half painted and I don't think it works - but I'll check with the parkers on.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
Re: Trunk Light
This it? Holes 58mm o/c. Yours for the postage.
![Image](http://i271.photobucket.com/albums/jj147/baltobernie/002.jpg)
Signing off now; got to load up for FFO.
Re: Trunk Light
Bernie, on the 80 and after, the clear plastic is a square shaped piece that just slipped on, into a grove. Not elongated like yours.
