1981 Fiat spider Transmission & Coolant recommendations
jahmalj
Post by jahmalj »
Hello All,
I am looking for recommendations for the transmission and radiator fluid on my automatic 1981 spider. It has been sitting so I drained the oil (SAE 30) and will drain the radiator and transmission fluid. I am learning about cars and this one in particular so please bare with me. :)
Jahmal
Frog2Spider
Your car is a: 1981 2000 Spider
Re: 1981 Fiat spider Transmission & Coolant recommendations
Post by Frog2Spider »
As per 1981 Spider Owners manual
- Engine Oil - 10w 40 (15w40 is recommended, but harder to find. DO NOT use Synethic. It will leak)
AND a Zinc Additive
- Coolant - 50/50
- Brake Fluid - Dot 3 (Do not use Synethic. It will destroy the seals in your Master Cylinder and Calipers)
- Manual Transmission - GL -1
- Differential - GL -5 ( 75/90 Gear Oil)
Owners manuals are available and highly recommended. They can be down-loaded free or bought from a Fiat vender specializing in parts for our cars.
Dave.
Frog2Spider
'81 - 2000 Spider
jahmalj
Post by jahmalj »
Thank you @Frog2Spider
Nanonevol
Post by Nanonevol »
Don't put GL1 in your automatic.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Frog2Spider
Yes, GL1 is for manual transmissions only, as stated. Just re-read your question.
An Automatic transmission is not a Fiat component. The Fiat manual has no automatic specifications and recommends having the transmission checked by a transmission shop, as different GM models were used.
Dave
Frog2Spider
'81 - 2000 Spider
jahmalj
Post by jahmalj »
@Frog2Spider I am not sure what you mean that the automatic is not a Fiat component. It's a 1981 Fiat Spider 2000 with an automatic transmission. Am I missing something here?
@Nanonevol Do you have a recommendation for the transmission fluid?
Jahmal
jahmalj
Post by jahmalj »
All,
I got it. I am showing the Dexron transmission fluid. Thanks for the help. BTW, I do have my manual now! :)
Jahmal
Post by RRoller123 »
They used a 3 speed Chevy automatic transmission, from a Chevette if I am not mistaken.
