Engine lifting points?
Lifting the engine and trans out (1.8L) and wondering what the best lift points are. I saw talk of a hook on the front but mine doesnt seem to have that anymore
- aj81spider
Re: Engine lifting points?
When I pulled mine out I bolted the bracket from my leveler to the engine using one of the cam tower bolts in the front. I don't have a good picture of that. For the other side I wrapped the chain around the exhaust manifold, which I hadn't removed (picture below). You could also probably use another cam tower bolt in the back if you are not going to pull it with the manifold.
A.J.
2006 Corvette
2006 Corvette
- Patron 2021
Nice hoist there AJ
