identify things for me
Rotoariesarecool
Your car is a: 1976 Fiat 124 Spider
Post by Rotoariesarecool »
Got some more questions about things
what is this little white canister in the trunk with lines going to it?
what is this canister that three lines from the gas tank go to inside the rear fender?
what is this unit directly after the master cylinder with two brake lines going in?
DieselSpider
Re: identify things for me
Post by DieselSpider »
I forget what the first two are but the second picture shows the carbon vapor recovery canister and more importantly the fuel overflow line disconnected so any overflows while fueling will drain into the trunk instead of out on the ground.
The third picture shows the brake failure warning switch with its electrical connection for the warning light disconnected.
blazingspider
Your car is a: 1977 fiat spider
Post by blazingspider »
The white canister in the first pic and the black canister in the second pic are part of the evaporative fuel emissions system. The black canister collects fuel vapors from three nipples on the gas tank. The fourth line goes to the "white canister" which is a valve that dependent on pressure, routes fuel vapors to the carbon canitser in the enigine compartment and allows make up air into the gas tank. If there's excess pressure is in the gas tank it will also vent it to the atomoshere.
