Lower Dash under the ignition that hides wiring?
cpreiti
Post by cpreiti »
Lower Dash under the ignition that hides wiring? What's the proper name for that part? For some reason my 81 is missing that piece. Where could i find that part? I would insert a picture but i cant figure out how.
cpreiti
Re: Lower Dash under the ignition that hides wiring?
Post by cpreiti »
cpreiti wrote:Lower Dash under the ignition that hides wiring? What's the proper name for that part? For some reason my 81 is missing that piece. Where could i find that part?
perthling
Your car is a: 1974 124 Spider
Post by perthling »
The later Coupes (73+) had a metal shroud around the ignition which also held the choke and accelerator hand linkage - and rear window demist switch on some models. Should screw straight on to a Spider's steering column as they were the same (at least early on, can't vouch for the 80+ models).
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
