Page 1 of 8
1971 Spider Restoration Puzzle .
Posted: Mon Aug 10, 2020 11:59 pm
by davebdave
Hi All,
I've started to assemble our 124 that I got from a friend who dissembled the car in preparation for a full restoration. I don't know anything about Fiat 124s but I'm going to try to put it together.
Here's the story of the car:
http://www.fiatspider.com/f15/viewtopic ... 01#p297155
Dave
Re: 1971 Spider Restoration Puzzle .
Posted: Tue Aug 11, 2020 12:02 am
by davebdave
Here is the blank canvas:
![Image](https://live.staticflickr.com/65535/50212280873_951eeee99c_b.jpg)
Posted: Tue Aug 11, 2020 12:13 am
by davebdave
I got the rear brake compensation valve on. I wonder why the lines are routed this way with such a tight bend away from the coilspring?
![Image](https://live.staticflickr.com/65535/50212310753_249892c565_b.jpg)
Posted: Tue Aug 11, 2020 12:23 am
by davebdave
Posted: Tue Aug 11, 2020 6:26 am
by RRoller123
Clever!
Posted: Tue Aug 11, 2020 10:49 am
by 18Fiatsandcounting
There is a trick to inserting these bump stops, but it sounds like you've found a good (better?) solution. I have to say, those bump stops may be the only thing on a Fiat that I have never removed. I have thought long and hard, and short of cutting out floor panels and replacing sheet metal, the bump stops are the only thing I can think of.
Since one of my current spiders is a '71, I'll be interested in following your story.
Posted: Tue Aug 11, 2020 12:10 pm
by davebdave
The bumps should be strong, don't know from an engineering standpoint how well they will work. I noticed searching online that Alfa bolts theirs on. Maybe that's why they were more expensive cars.
![Image](https://live.staticflickr.com/65535/50214933947_320ca11215_b.jpg)
Posted: Tue Aug 11, 2020 12:27 pm
by davebdave
18Fiatsandcounting wrote:There is a trick to inserting these bump stops, but it sounds like you've found a good (better?) solution. I have to say, those bump stops may be the only thing on a Fiat that I have never removed. I have thought long and hard, and short of cutting out floor panels and replacing sheet metal, the bump stops are the only thing I can think of.
Hey Bryan, I'm glad you will be following. I'm sure I will have questions and it sounds like you're a good person to ask.
At the moment I don't know enough about what I don't know to ask a question.
Dave
Posted: Tue Aug 11, 2020 4:20 pm
davebdave wrote:I'm sure I will have questions and it sounds like you're a good person to ask.
Thanks, and I'd be happy to try and help. I get pretty weak in terms of knowledge once you move past 1978 spiders, but that's not an issue in this case.
Posted: Wed Aug 12, 2020 10:37 am
by davebdave
Wow steel lines are a PITA to bend and I'm not very good at it. I may need to install a few clamps to hold the lines clear of the driveshaft.
![Image](https://live.staticflickr.com/65535/50217786628_2fec485d72_z.jpg)
Posted: Wed Aug 12, 2020 4:22 pm
OK, I was wrong: I also have never removed fuel and brake lines to the rear. In the front and on the rear axle, yes. Down the driveshaft tunnel, no.
Anyway, good work!
Posted: Sat Aug 15, 2020 2:18 pm
by baltobernie
FYI, the 1971 model year has unique tail lamps. If your purchase did not include these, start looking now, or consider a small amount of metal work to fit the shorter 1972-74 ones before going to paint.
Posted: Sat Aug 15, 2020 5:20 pm
baltobernie wrote:FYI, the 1971 model year has unique tail lamps. If your purchase did not include these, start looking now, or consider a small amount of metal work to fit the shorter 1972-74 ones before going to paint.
Very true that. The tail lamps assemblies in mine were OK but not great, so I went with exactly this solution. The '71 lamp assemblies wrap around the rear-to-side crease ever so slightly, while the later ones do not.
Worked just fine, and while not original, I kind of like the yellow turn signal portion of the lens. My original '71 was all red (except for the backup light portion of the lens).
Posted: Tue Aug 18, 2020 8:37 pm
by davebdave
Thanks for the info on the tail lights. I appear to have a good set of originals and possibly some reproductions.
tail1 by
Dave W, on Flickr
tail2 by
Dave W, on Flickr
Posted: Wed Aug 19, 2020 9:29 am
by RRoller123
Rare as Hen's Teeth!
