![Razz :P](./images/smilies/icon_razz.gif)
I've finally got the thing to run without overheating... or dying... or all the other ailments it's had.... and been able to actually drive it. This is a WIN
![Very Happy :D](./images/smilies/icon_biggrin.gif)
BUT, before long it was dead again....
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
I know this, because I've had the top off the carb immediately after the symptom and the fuel level in the float bowl was below the jet orifice. When running normally the fuel level is higher in the float bowl, so it looks like the pump isn't keeping pace with demand. Question - what level should the fuel be at in the float bowl in normal operation and where do you measure it from?
The mechanical fuel pump has been replaced with an electric one. These can flow plenty of fuel, so I don't know why it isn't keeping pace in this situation. I don't know if it's pumping it back to the tank via the return line and just not filling the float bowl or what's going on!
![Confused :?](./images/smilies/icon_confused.gif)
I've had the float valve out of the carb and can't see any issues with this. I have observed bubbles coming into the fuel filter, which is odd and suggests maybe there might be an air leak in the supply pipe? but there are no signs of fuel anywhere.... I guess it could be the pick up in the tank?
Any thoughts or ideas would be welcome.... I'm determined to get this Spider running properly and back on the road where it belongs!
