Page 1 of 1
Back at it- need help
Posted: Mon Feb 20, 2023 8:20 pm
by Yadkin
After several years of pre-retirement "busy" ness and delays by my painter I've got the car back into my tiny garage and final assembly. I looked through all five bins of materials and can't seem to find the front hood latch. I'm probably not using the correct term which is why a word search was futile. This is the mechanism close to the hood hinge on the driver's side. It looks to be held in place with three screws in a triangular pattern, and holds the spring loaded rod to keep the hood vertical when it is fully opened.
I'd be much appreciated if someone could snap a picture of theirs so I can have another clue as to what I'm looking for.
Re: Back at it- need help
Posted: Tue Feb 21, 2023 12:42 am
by Zoofly
I think this is what you're looking for.
Posted: Tue Feb 21, 2023 7:52 am
by Yadkin
Zoofly wrote:I think this is what you're looking for.
That's it, thanks. I looked through my 5 bins of bits and it's nowhere to be found. Thankfully Vick's makes a reproduction, and it's on order.
Posted: Sat Mar 04, 2023 6:47 pm
by Yadkin
Can anyone identify this part? I thought it was an air shield under the radiator but I can't figure out how to attach it. It's a little under 27" wide, heavy rigid plastic with a steel bar at one long side.
Posted: Sun Mar 05, 2023 10:24 am
by 18Fiatsandcounting
I can't recall ever seeing anything like that on a Fiat spider. Perhaps someone added it as a protective cover of sorts?
Posted: Mon Mar 06, 2023 8:15 pm
by F16Waldo
18Fiatsandcounting wrote:Perhaps someone added it as a protective cover of sorts?
I think Bryan may be right. Eerily similar to the size and bolt hole pattern as this "oil pan cover" installed on my 83 in 2019.
https://www.vickauto.com/parts/oil-pan- ... u-54-0300/
W
Posted: Tue Mar 07, 2023 10:08 am
by Yadkin
F16Waldo wrote:18Fiatsandcounting wrote:Perhaps someone added it as a protective cover of sorts?
W
You gave me a clue, thanks.
Installs very easily onto the front tow hooks on either side of the radiator and into the back flange of the crossmember. Does not include hardware.
Posted: Tue Mar 07, 2023 11:22 am
by Yadkin
It has the correct width to bolt onto the tow hooks, but I only have one hook. And the profile is all wrong to pass under the oil pan. My guess, this part got mixed up from another car at the shop it was in for several months.
