Today I took off the air filter housing so I could get a look at the hoses on the carburetor. What I found is pictured below. I was pretty sure that there was fluid leaking from the carburetor – looks like those hoses might be the source.
I looked in the manual I have – but it’s not specific enough to have info about those hoses (Part Numbers – what exactly they are/do). I want to make sure that the hoses that I replace them with are both the proper size and made of the proper rubber for the jobs they do.
So, I have two questions:
#1. Can anyone tell me what those two hoses are and what their part numbers are?
#2. Can anyone point me in the direction of a guide that has part numbers and illustrations for a 1978 Fiat Spider 1800? It seems like I will need this info quite often.
I also found this hose:
It’s not connected to anything. I can’t tell if it came off of something or if it was intentionally disconnected. This car was a California car at one point. I’m wondering if this is just part of the emissions system that someone disconnected. I noticed that the two relays on the right side of the image are also disconnected. Again, a detailed shop manual would be really helpful. The Chilton’s guide I have is from 1978 and covers many different models/years of Fiats – so it’s very little help.
If this isn’t being used can I just remove it? It seems like having hanging/dangling parts in the engine compartment is dangerous.
