hi all
Im still looking for a way to power up my (now fuel injected) spider, so maybe im planning a engine swap
What do you guys think about this engine?http://link.marktplaats.nl/203374571
it's an engine from a fiat ritmo abarth 130 tc in case the link doesn't work
does that fit ?
what do i have to do to make it fit?
greetings from holland
stephan
abarth 130 tc engine
- Blast
Re: abarth 130 tc engine
Hello Stephanspider2000,
I'm no Motorhead by any means, but besides probably having to make custom motor mounts, changing trannys, driveshafts, shifter modifications, and exhaust changes, I'd think it'd be a monster of a job. Theres just a lot involved, and I've seen very few who have attemped it, complete it. But good luck, and let us know if you try.
Jet Setting on Minimum Wage Baby!
- vasek
- Your car is a: Fiat 124 Spider 1972 BS1
I would like to do same conversion
but my situation is little bit more complicated, because I have 124 BS1 (1608) Spider and 2l block is 17mm taller - this is the reason why Spider 2000 have bigger bumps on the bonnet. If you have Spider 2000, I think you can directly swap engines without any modification.
V.
V.
