I put my old carb back in, and then started it up. I was keeping the throttle open by hand under the hood while adjusting the mix screw and idle screw. As I was doing so, the hose that comes out of the crankcase was spraying blow-by onto my hand so I moved it a couple of inches to the side. When I moved this hose it touched something up under the engine and made a BIG spark. I wasn't sure what happened at first, so I jiggled it around again, and again got a big spark from somewhere down by the bottom of the engine. With all the fuel hanging around from having the carb in and out I was concerned about a fire, so I disconnected the battery, put everything away and came here.
Can anybody suggest what the deal might be?
-- se
