I really need help here...
In the middle of rear pad/rotor replacement and cannot get piston to screw back in...
I'm applying pressure as i try to turn it
the axle is supported to ride hieght
there is little if no corrosion on the pistons under the boot
the e-brake is off but not disconected
I'm sure/hope it's something stupid I overlooked
Ray
Help with rear brakes
i found an eazy way to get the piston to screw back into the caliper. first, sense you have to take the brake pads out any how take the caliper mounting bracket off and remove rotor remount the caliper and bracket sands rotor and pads the get the little brake tool from auto zone and extendtion and racket that pita back into the caliper
