My guess is questionable lubrication. I should probably go back and read the threads about motor oil recommendations. I've been running 20W-50 and 10W-40, with no criteria on picking a certain brand, and changing every 5K miles, with most of these miles being put on the car with cross-country extended freeway driving at 75 - 80 mph.
Anybody had this type of wear on the valve shims? I've never seen it before it in the 100K + miles that I've put on this car (mostly 1438cc stock engine). The last 20K miles have been with a 1.8L modified engine with some mildly agressive cams. The intakes (40-80) are set at .011" per PBS engineering recommendations. The exhaust (70-30) are set at .019", also per PBS recommendations. Maybe the exhaust cam is missing the ramp at the .019" gap and needs to have clearance reduced to catch the ramp better?
Any thoughts? Thanks in advance. Alvon
