waterpump R&R
waterpump R&R
I need to replace the waterpump on my 2L today. Is this possible with the radiator in place? any things to watch out for, or is it pretty straight forward?
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
Re: waterpump R&R
Can be done with Radiator in place. Not a bad job. Couple of hours. Just remember that there is the pipe out the back, under the exhaust, that has 2 bolts that are part of the water pump. Even torque on all bolts.
Good lucks
Good lucks
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
79 Spider 2000
carb
- Tappy
Re: waterpump R&R
on the other hand you need to let coolant of anyway and 2 bolts away from removing the radiator will give so some extra space ....
FineItalianAutomobile Technology
Re: waterpump R&R
Thanks for the replies. I see here now it comes with a paper gasket. sealant on the gasket or just the bare paper gasket?
- TulsaSpider
Re: waterpump R&R
Use sealant! I just did mine, easy job, I didn't bother with the radiator, but drain the block. On mine I did run across the problem of one of the studs stripping out on me.
- TulsaSpider
Re: waterpump R&R
permatex? I just use typical RTV Maybe they are the same?
Re: waterpump R&R
I'd use permatex, with the exception of the heater pipe. If it's warped I'd use rtv there. Tap the bolt holes for the pump and use antiseize on the threads
