Also, once I removed the oil pump, I found several pieces of the red gasket sealant the PO used over zealously in the pick-up screen, is there a way to flush this debris out? I have collected all that I could see but I want to make sure it is all gone. Also is sealant necessary? If so what do you all recommend?
Finally, I have heard many times that you are not an official 'Fiat mechanic / owner' until you replace a starter. Having gone through the process of getting the old pan off and half way through getting a new pan on, I think this process should qualify you a well. At this point, I would be quite happy to catch a starter in the face and lose some knuckle skin, as not to have to contort my body to re-install the oil pump inside the pan AGAIN!
