Where is it located? Do you just unplug and replace with a new one? Will you loose some anti freeze? Any comments are appreciated. Im going threw everything to cure cold rough idle. AAR is next and I have found a small crack in a vacuum hose.
replacing coolant temp sensor?
Re: replacing coolant temp sensor?
You are f.i. right? It's on the coolant tee at the front of the head just beneath the bleeder.
Trey
- Your car is a: 1982 Fiat Spider 2000 Turbo
You will lose some antifreeze (very little) and will have to bleed the system after you have replaced the sensor.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
Thank You for the info. How do you bleed the system? Also is it possible to take the AAR out and clean it out?kristoj wrote:You will lose some antifreeze (very little) and will have to bleed the system after you have replaced the sensor.
Thanks.
the aar won't get dirty, it only has filtered air going through it. Most likely it needs to be replaced
Anyone know where I can find a new AAR? They seem hard to come by? Haven't found new, just a used one. Any thoughts?
If you can find one new it is very expensive. Mark's got rebuilt units for a lot less. (http://www.allisonsautomotive.com/)
Mark, Ive sent you an email to your hotmail re: AAR. Thanks
