Distributor interferes with hood
Strange issue, but my topmost wire terminal is hitting the hood when closed and the wire boot is getting badly chafed. Is there anything that I can do to the dizzy's orientation to fix this?
Re: Distributor interferes with hood
You can reinstall the dist with the cap facing another direction, (down or sideways), it just has to be timed correctly.
Trey
So all I have to do is pull it out, re-orient it, and redo the timing, right?
yes, and hope the plug wires are long enough to reach the plugs
Cheers mates!
I have some slackage in the wires, so a slight turn to the right should do it.
I have same problem........... I tried taking out the dizzy and tried the orientation to a better spot. But when I go to time it correctly, it goes back tot he same spot?
- kilrwail
Here's the correct orientation and wiring. There shouldn't be any interference this way.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
