Questions: The brake pedal is very soft. I have bled them thoroughly, but the pedal remains soft. I believe there is a very slow brake fluid leak, but can't locate it. From the spot under the car it looks to be coming from the area of the reservoir or the booster. Is that a common place for a leak?
I'm posting a pic of my engine. The car had the turbo package originally, but it was either removed or the engine swapped out before I got the car. As you can see there are several vacuum tubes and other hoses sealed off. The car runs OK, but I believe it can run a lot better with some work. Any identification of parts to help me map the engine compartment is greatly appreciated!
I have looked for the engine # without success several times. How small is the number stamp on the block?
From my research it appears I have the worst carb/intake combination, and am considering going to a single plane manifold and different carb. Advice?
Thanks in advance!
Brian
