Here are the timing marks. crank was set at zero with the big yellow timing cover installed, then i took it off. Its kind of hard to see but I marked the marks with a Red marker which didn't show up very well. The camshaft sprokets are aligned with the pointers pointing to the holes in the sprockets, the auxilary shaft is aligned at 34 degrees off of 90 degrees and the crank is aligned at zero. When all done: the crank and cam marks do NOT exactly align as perfectly as the book says they do. Thus backing up the reason to get adjustable cam gear sprockets.
In this photo, the crank is dead on perfect with top dead center and here is where the cam gears align in real time. Note the exhaust cam sprocket hole is forward of the timing mark pointer. alignment is forward of the true timing mark
