Can one of you suspension experts help me identify these. Which ones are upper and which ones are lower? It's my understanding that the pair in the pic on the top are upper and the pair on the bottom are lower. Here's the problem... if that's the case the uppers dont fit through the hole on the A-arm, they're too big and the bolt holes dont match up. Putting the ones that I think are the uppers (in the pic) on the lower A-arm they fit through the hole but the bolt holes don't line up. The lower ones in the pic (two different brands) fit fine in both the upper and lower.
Any ideas? Did the vendor give me the wrong ball joints or am I doing something wrong.
On a side note: should you grease the ball joints before installing the boot. New they look like they dont have any grease in them?
Thanks, Rick
