I called Bruce, he does not carry it. Vick Autosports does not have it.
![Question :?:](./images/smilies/icon_question.gif)
![Image](http://forums.rennlist.com/upload/dsc01422sm_small.jpg)
Cool! That was easy.manoa matt wrote:You mean a black rubber washer? Try the plumbing section at the hardware store. Just bought some for a rack I sold last week. $0.16 each (X 4)
None on mine when removed so I attache the same way thus using the grommet for my weather seal. Thx for the inputmanoa matt wrote:Jim,
The cars came from the factory wired for radios, dealers did not know this when they went to install them, thereby adding and splicing in more wiring creating a birds nest of wires in the center radio console.
Fiats were transported from Italy to the east coast on the top deck of ships without any cover or protection, when they arrived at the dealerships, the dealers only washed off the body and not the undercarriage, then undercoated the cars effectively locking in that salt spray, hence why they rusted out so quick.
Any thing else you want to hang them by now?
Also when you installed the rubber grommet, did you elimenate the tapered pot metal washer and fasten the rack right to the rubber grommet? If so that will seal out water, but if that tapered pot metal washer is still there, and the rack sits directly on it, water can seep in at that joint. You need another washer or o ring between there or water will get into the trunk.
