Well, I think it's time to replace my coolant hoses as I don't know when they were last replaced but they seem a little bulgy and soft. I noticed when I did my first flush and fill the radiator was still pretty dirty internally. So, instead of just replacing the hoses I want to pull the radiator(which seems straight forward) and clean it or get it cleaned by a shop and paint it, what have you guys done to get yours cleaned out? It's the automatic trans type. BTW, What company has the most accurate type of replacement hoses? IAP, Vicks, etc.
I also want to remove and clean my timing belt cover because the bottom of it is pretty grimy and I'm trying to see where some slight engine leaks are coming from. I also noticed that the bottom bolt head to the timing belt cover broke off, so I got to see what I'm gonna do about that.
Another thing is that I think my oil pan gasket might be leaking and the pan has some tiny dents in it and needs painting but not sure if I can handle the procedure to unbolt the pan because of the engine clearence problem.
