Hi Folks,
Doing some metal work, fixing some small holes, etc. When done I plan on coating the floor with POR 15. My question is, has anyone applied POR 15 on the rubber coating? I removed some of the rubber coating where I'm doing the repairs, but want to know if I need to remove all of it.
Dave
POR 15 application
Re: POR 15 application
I think you should remove all the rubber coating and make sure you have a clean and 100% dry surface. In fact, I would not apply POR 15 on a Humid day. Any moisture will be trapped between the new bonded surface and the metal. This is one of the main reasons I would remove all jute and residue on the floor. I've had POR 15 on my Spider Floors for about 10 years now with no issues at all. I have heard horror stories from car owners that had moisture trapped. Also, I would not apply POR 15 anyplace that might be exposed to sunlight after application. As I understand it, sunlight breaks down the POR15.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Thanks for the feedback. I'll take this advice. Some more effort now for less headaches later.
Dave
Dave
