So step one, strap down the top:
Then the back hooks:
Then the front plastic clips:
I'm missing the snaps, so no snaps on the side.
But finally, I have some hooks at the bottom of the cover, that I'm not sure what to hook to:
Where do I hook those?
Which panel are you talking about? I have a backseat there, not a deck. Or are you talking the side panels?johndemar wrote:On the rear interior trim panel there should be a hole for the hook. Was your panel recovered?
I just tried putting it over the point. Its much tougher to do that.. It ends up slipping off, pulling the latch back to more or less the same position I have it. It doesn't really feel like that much pressure in its current position.dmwhiteoak wrote:In your first picture I believe you have it hooked wrong. The strap goes over the point with the latch closed. Seems like your putting alot of pressure on that latch the way it is now. Mine has holes in the side covers on both sides of the back seat.
