Trying to get it to the "sunny day driver" stage over the winter. Knew she needs clutch, head gasket etc., began with disassembly to prepare pulling engine/transmission.
The good news: new alternator and starter, engine mounts and doughnut in good shape.
The bad news: engine has been replaced - s/n 132A1.040.6 That makes it 1756 cc (1800) engine, right? The cylinder head has four threaded inserts that have been cut off and sealed. Abandoned air injection? The crankshaft pulley has two "extra" grooves that are unused. Air pump and ? Cold compression is 95, 100, 100, 95, which isn't too bad for a "smog" engine.
Now the weird part: the carb is a Weber 28/36 DHSA, with vacuum secondary. I'm looking at a Bayless catalog, and it says that the stock 132 engine has a 23/27 carb. Mine has the multiple fuel inlet "Christmas tree" typical of a smog motor, and nothing appears to have been jerry-rigged, although what seems to be a fast idle step spring was unattached at one end. Any ideas as to this carb/engine combination?
Bernie
