Cross member stud question
burlybryan
Post by burlybryan »
Recently rebuilt the front suspension. Got a call from the alignment shop saying that one of the crossmember studs is spinning and can't be torqued. Are these replaceable or in any way serviceable? Could it be welded? Please don't say I need a new crossmember - these are way too expensive!
Thanks.
Bryan
'82 Spider 2000
burlybryan
'82 Spider 2000 FI
'12 500 Sport (Verde Oliva) - wife's daily driver - when it's not being fixed at the dealer...
burlybryan
Re: Cross member stud question
Posted first, searched second. Appears that bolt/stud can be welded as long as the surrounding metal is sound. My crossmember is in very good condition - very little rust on the suspension of this car.
Might as well replace the sagging spring while I'm there....and it never ends. Hopefully I'm driving this thing before it snows.
burlybryan
'82 Spider 2000 FI
narfire
Post by narfire »
I'm figuring the/a stud the lower a arm attaches to... has broken the weld. Mine did that several years ago and I had a friend weld it back on. Fine now for 3 years.
burlybryan
Thanks! That's the plan. It looks like I can't weld it in it's little boxed housing but the peened over or flattened end should be accessible. Time to make some sparks.
