adrians wrote:Yes, water will pour out when you remove the old switch ... so drain it first.
Also a quick word of warning, those switch with the leads may not be exactly the same temperature range as the original one, so the coolant will get hotter prior to the fan operating.
I would check the switch with a pot of boiling water and a thermometer and compare it to the old one, if still operative.
I found out by experience !
Hope you don't mind a long reply question..Boiling water boils at 212 degrees so is this the degrees that the switch is designed to come on .?
And are you saying that the original didn't have leads ? Either some one put a new one in some time back or the one that is in there now is the original and it has leads.
I suppose I could check it this way .
Get a pot of water and put it on a hot plate and put the hot plate close to the car where I can hook the switch submered into the pot of water. ( of course only the part that is supposed to be submerged) then hook some longer wires up between the fan motor and the switch .. start heating the water and watching the thermostat so when it makes the fan motor run then that would be the degrees that the switch is set at to work .
I am open to all ideas if this is more than is needed. thanks by the way ,,papa
