Hi Tima01864,
Owartrol is perfekt to infuse rust.
Sorry i, need to get a bit deeper in this than you might expect but i think it is the best way to explain the usage of owatrol.
Rust is hydrophilic, and thats the reason why rust will never stop. The water in the rust reacts with the metal and the rust get deeper and deeper and deeper... If you aply owatrol on rust it will repress the water and drys the rust - perfect the transformation is stoppped.
But Owatrol is water soluble ( correct word?!? ).
If You put it into the inside of the rocker panels the effect wont last long.
I do not know how Owarttol reacts with something like Fluid film. ( if You like to stop the rust inside the Rocker panels i think fluid film is better than Owatrol, because it is not washed away by water...
Owatrol is the hero when rust in folds is your task. There You will have to simply drop it in the fold till it the whole fold is filled, let it dry, cover the fold with an sealant and after that cover it with an rust preventing paint ( i use Brantho 3 in1 because it is used by thousand for this purpose). The Owatrol is here used to repress the water in the rust of the fold - we used it to stop rust in an mercededs door two years ago and coulnd finish it - the Owatrol was not covered but the rust stopped till now and we do have a lot of rain here in Hamburg
![Wink ;)](./images/smilies/icon_wink.gif)
it is perfect...
My whole Spiders folds are covered this way and i dont think that there will be any rust in any fold again...
For more infomations about owatrol use this link:
https://owatrol.com/en/
When i suggest to use some specific products i do this because i have used them and feel comfortable with them, if you know products beeing better give me a note i like trying new stuff
Basso
