My problem is that I (not an electrics guy) don't know where the ignition wires go (which posts, 30, 50, 1N, 15 etc) and if an open pin on the 5-pin relay center is ok or something goes there.
Symptoms;
1. Solenoid/starter works fine when red & red/black is powered.
2. Won't start (no coil power) and no power to accessories even when relays' red lead is powered
Questions:
1. Where do the 3 (or 4) ignition wires plug into? 15, 30, 50 etc.... See #s 1, 2, 3, 4 connectors on diagram.
2. What (if anything) plugs into the center of the "Pinks" relay? (if I plug the loose brown - brown/yellow connector there it buzzes bad under power. The accessories do come on but the tack jumps a lot (motor off)). See #5 connector in diagram.
https://imgur.com/gallery/F5QVvYy
