Keeping battery charged up when not using car
Fiat88
Post by Fiat88 »
Right now I'm not using my battery since I'm doing some front resto work and maintenance. Can't start the car up becuase I have the rad out. What's the best way to keep the battery from dying. I have the negative off, should I buy a trickle charger?
htchevyii
Re: Keeping battery charged up when not using car
Post by htchevyii »
A "floating" type battery charger, Battery Tender is one brand, works good and won't overcharge your batery.
Trey
SLOSpider
Post by SLOSpider »
Solar panel plug in if it sits outside!
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
MikeR
Post by MikeR »
I have been using a (Swedish) CTEK Multi XS 3600 charger / multi-cycle conditioner successfully over the last couple of winters. They are becoming very popular with classic car owners in Europe but I dont know if they are sold in the US.
It comes with a semi-permanent eyelet connection and plug-in connection and croc-clips are included for a less permanent set up. I have fixed the eyelets to my battery with the connector plug external to the battery cover. The unit is designed for long term connection and it works very well.
a really inexpensive trickle charger can be made from an old ac adapter. Cut the lead off and use two alligator clips
baltobernie
Post by baltobernie »
I dunno about that, Mark. Even the tiny output of an AC adaptor will eventually overcharge an auto battery. (Ditto with the solar cells). Better to get a float charger made for that purpose. Some of them are pretty inexpensive; the Chinese ones are ten bucks.
If the battery is in good shape, it should be able to go for several months (disconnected) with no ill effects. Can you maybe put jumper cables on it from another car once in a while?
Fiat88
Post by Fiat88 »
Went to pepboys and picked this one up:
http://store.schumachermart.com/sc-600a.html
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
Fiat88 wrote:Went to pepboys and picked this one up:
+1
I use this one for the cars and for the motorcycles. Who said our cars were not hybrid... :D
http://store.schumachermart.com/sem-1562a.html
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
