Carb Options
nettxtra
Re: Carb Options
Post by nettxtra »
I am now kissing you on the cheek, and hope you have heeded my advice about other modifications necessary to run this carb in a street application.
Now I use a weber 34 ADF, I also have a set of 2x40 IDF.
I like the best 34 ADF, it seems as if it provides the same power as the IDF's up to about 5000 rpm, and it's in this area runs most of the time.
Sometimes I miss a little bit more in the top, can a weber 38 give me that?
Engine:
2 Liter
Cam - 285V-street performance, power range 2800-6800, Slightly lumpy idle. Spec-285 duration, 385 lift
Exhaust system is a 2 1 / 4 "high flow system
What will be the best carburetor for this setup?
baltobernie
Re: Carb Options
Post by baltobernie »
You didn't mention that you already have a set of IDFs. They give the most power, as you've already discovered. Once properly synchronized, they shouldn't be any more maintenance than a single. Plus, they sound great!
ljayr
Re: Carb Options
Post by ljayr »
Thanks for all the great info guys!
For the time being I have picked up a 32DATRA and what a difference that has made. It may not be a direct bolt on, but it didnt take that much effort either.
Over the winter I'll have to save my pennies and find a more suitable replacement or just convert it over to fuel injection and be done with it.
Again all of the input was very much appreciated.
Jason
nettxtra
Re: Carb Options
Post by nettxtra »
I know that the IDFs are good :-)
But, what are the best single carburetor one can use? For best performance
maytag
Re: Carb Options
Post by maytag »
well there are a LOT of opionions in this thread, and they'd all be good.
so sell me your IDF's and try something else?!?!?! :mrgreen:
Or I'll trade plus cash for my 32adfa?
