The plugs I pulled out are, in cylinder order:
#1 NGK BPR6EY
#2 NGK BPR6ES
#3 NGK BPR6EY
#4 NGK BPR3EY
The threaded portion on the ES is noticeably bigger around, and shorter than the EYs. Is it typical to have two different sizes? I can also see, in the engine, that the hole for the plug on cyl #2 is visibly bigger than the other three (which stands to reason, since the plug itself is bigger).
Also, How would I determine if the plugs really need to be replaced?
Now for a question on the wires. The wires have printed on them "7mm Premium Silicone Magnetic Suppression". No brand name that I can find. They also appear (to my untrained eye) to have been cut to length and had the metal ends crimped on. This may be why the metal ends came off when I pulled the wires off the plugs (i.e. they weren't crimped on hard enough to stay with the wire). Is this common? If I replace the wires, what specs do I need to look for, and do I need to find particular lengths, or will I need to cut them, or if they are long, should I just leave them long?
Thanks!
-- se
