The motor I put in is a European /118hp / 1800cc with manual choke and it seems to be in good condition. I have it up and running now but it won’t idle without 30% choke.
I have cleaned the carburetor (Weber 34 DMS) and checked that everything is working properly, so far I only found a small air leak in the carburetor axel seal but it’s very minor and was only detected by using starter gas (propane).
I also checked the ignition (Marelli S147) with the strobe light and found it was uneven on some cylinders so that needs some attention too.
Is there anyone here that might have more suggestions what to check?
Its starting to get critical since I’m going to a Italian meeting 1st of May and there is no way I can go like this.
I appreciate all information you all can give me so that I can resolve this quickly.
