Single point conversion
I read an artical on converting from dual to single points that stated to run a wire from the negative side of the coil to the point and remove all else. I tried that and my tack stopped working. I reconnected the original wiring leaving one point disconnected and the tack began to work again. Does anybody know how to get around this so that the tack works with the conversion? I think the single wire from the coil looks a lot cleaner.
Re: Single point conversion
you've got a relay in the system that should be bypassed
Sorry, don't know the answer, but I do know IAP has a tech tip on the conversion. Unless that's the article you read, then I'm no help.
http://www.international-auto.com/fiat- ... ersion.cfm
Trey
- TulsaSpider
I have an electronic ignition for sale if you are interested.
- kmac33
- Your car is a: 1974 Spider
Which electronic ignition set-up do you have to sell? I may be interested.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
- TulsaSpider
Sorry I have a stock Fiat. It needs the internals but most people would replace that stuff anyway.http://www.fiatspider.com:16080/f08/vie ... =11&t=5651
