'Carefully align the new fuel pump with the mounting holes on the engine block, making sure the pump's lever arm is properly seated below the fuel pump lobe on the auxiliary shaft. This is vital for the pump to operate correctly. It may take a little wiggling and pressure to get it seated properly."
Jim
